Compactlogix Channel 0
cornbread
Feb 2007
madison, indiana
407
I'm trying to talk to a Compactlogix using channel zero. In RSlinx I have my USB 1747 driver set up and it auto configures just fine, however when I got to Who Active, I see nothing. Any pointers would be greatly appreciated.
I'm using RSlinx classic lite 2.57.00.14
Make sure the Auto-browse box is checked, or click Refresh, for RSLinx to try to browse the device.
Strictly speaking any point-to-point connection should ignore the Source and Destination bytes, but you might try configuring RSLinx Classic as a node address other than 0.
Aha... are you using a 1747-UIC ? Those are for DH485 protocol, which the CompactLogix supports but it's not the default.
The Autoconfigure, in that case, is the DF1 driver in RSLinx talking to the UIC device itself. There are specific configuration requirements for the 1747-UIC.
It's more likely that you need an ordinary USB/RS232 converter to connect using DF1 Full Duplex protocol to the CompactLogix.
Hello, I am attempting to use the 1769-ASCII 2 Channel Module with a CompactLogix 1768-L43 Controller to connect to two AccuRange AR 700 lasers...
7,953
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
43
260
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
147
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
115
