Hi all, i have a CompactLogix L32e and a network module 1734-aent. I've made an ethernet connection on the same network (with an hub) and all works.
Now I'm trying to put the PLC in a different network from the 1734-AENT module (on the same hub) but I can not make them communicate with each other.
For example i would to put the L32 in a network with ip 10.12.0.100 and the module in a network 10.10.0.90 with both subnet mask 255.255.255.0 but the plc doesn't see the module.
I have set up even the gateway in both devices with their respective ip but doesn't work.
How can i do?
Thank you all.
How can i do?
Thank you all.
