Control Logix RS-232 card?
doug2
Dec 2006
California
181
I need a RS-232 port to send ascii strings to a computer. We don't want to tie up the comm port on the processor. I know the SLC had a BAS module. Is there a simular module for CLX?
Check out 1756-MVID.
Depending on what you wish to do, and what you are communicating with, you may be able to do something through the 1756-ENBT or 1756-EWEB.
There are other vendors of specialty modules for the ControlLogix platform.
Thanks guys. These look good.
I simply need to send weights from the clx to a computer running a c++ application that will print the tags.
Has anyone used the rtautomation module yet?
I haven't used the above unit, I have used Digi, and I have used the Prosoft module. The prosoft module is probably the easiest, but the converters are cheaper even when you factor in the time spent messing with them.
we have a barcode verification that is supposed to talk to the plc via serial but is not. anyone have any ideas? it is a datalogic cbx100.
2,122
I have an OMX RS 232 control interface unit which needs to be interfaced to Compact logix plc using rs232 communication protocol. I need to read...
4,560
Hi, My system has 5-6 weight indicators including with RS232 or RS485 port. I would like to communicate these weight indicators via the control...
2,728
G
I want to use a 1756 processor RS232 port and link for bi directional communications with a RS485 link to one device. Can anybody suggest a good...
5,280
265
