Control valves
Jan 2003
Michigan
490
Hey all. Im back to pick your collective brains again. Im attempting to locate a new control valve system. Currently we use either the built in valves on our flow meters (which work great, but the flow meters dont) or we mount a port valve and attach a honeywell modutrol motor too it with a bracket and linkage setup. The bracket and linkage is far from ideal tho. What I would like to find is some sort or control valve / port valve that has built actuator with 4-20 control. Anyone know of any products like this? I havent had much sucess myself. Thanks
Matt
Were typically controlling hydrocarbons (methane, propane, etc), air, ammonia, and hydrogen (as well as mixes of h2 from cracked hyrdocarbons or dissassociated ammonia). Pipe sizes are 3/4" to 4".
Thanks!
Just curious, what are these "built in valves on our flow meters"?
What type of flow meters?
It suprises me that you're working in the process industries and several valve manufacturer's haven't found you already.
Aren't some of those gases hot, coming out of the dissociation process?
Presumably you drive the Modutrol actuator with a 4-20mA?
Anyhow, somehow or other you have to power the actuator. The choice is pneumatics (air) or electric.
Two advantages of the electric Modutrol actuator:
- mounting puts it above and away from the valve where it cooks less if the medium through the valve is hot.
- electrically powered, you don't need instrument quality air, meaning, clean (no oil) and dry (low dewpoint).
If you switch to a pneumatic actuator, there are costs of either providing and maintaining instrument air or dealing with what dirty air does to the I/P or pneumatic positioner that converts your 4-20mA signal to pneumatics.
It sounds like the non-flow-meter valves work OK. What is a port valve? Is it a butterfly style valve or a globe (plug) valve?
Are you going through all this to get rid of linkage? What's the real problem with linkage? Setup? It sticks out and gets knocked around and bent? Never quite right? Non-linear response?
Dan
Evening All, Hoping for some advice & any suggestions on a tank control system that we will be looking to optimise soon. We have a tank that we...
25
4,270
Hi all, i'm after some help on a flow control valve control strategy. There are 8 parallel vessels that require evenly distributed flow. Each...
32
7,027
Hello, I want to ask about types of control valves that don't need air compressor as actuator, is there is a selonoid valve that can be actuated...
2,666
Hello experts, can you please help me understand the meaning of symbols shown in the attached pictures? First is U/S (I guess U represents...
1,963
Dear all, please i want your help to rank manufacture for shutdown and control valves as i work on a project and the vendor will not bring fisher...
2,001
