Hello,
I have been trying to learn how to communicate to a panelview display using control logix with a 1756-dhrio module, using the remote i/o communications. I have searched this forum and allen bradleys knowledge base articles. This is what I think I know:
1)configure 1756-DHRIO module for RIO, this I have done and have no problems with.
2)create read and write messages in the control logix program, again done and no problem.
3)set up the panelview terminal setup screen to panelview 1000 and protocol to RIO. done and have no problems.
4)set up panelview communications (HERE IS WHERE MY PROBLEMS BEGIN)
a) 1st I set PLC/SCANNER TYPE to the CONTROLLOGIX setting and SET Name to THE correct Address.
b) 2nd set up the block transfer addresses. Here I set the block transfer addresses to the same tags reffered to in the plc message setup instructions in my controllogix plc program.
ADDRESS: PV_READ_DATA, MODE: READ, LENGTH: 64
ADDRESS: PV_WRITE_DATA, MODE: WRITE, LENGHT: 64
AND CHECK THE ENABLED BOX NEXT TO BOTH.
Now when I try to VALIDATE the program I get the error (8055) which is invalid panelview terminal block transfer channel address. So I uncheck the enabled box next to the block transfer addresses and VALIDATE again and the error dissapears. THIS TELLS ME MY BLOCK TRANSFER TAGS ARE NOT CORRECT.
SO further research has showed me that I now have to map my control logix tags to the plc 5 type addressing in the plc. This I think I can do with no problem. BUT I ONLY HAVE A COPY OF PANELBUILDER32 AND NOT RSLOGIX5000 AT HOME.
now looking at the examples from ab's knowledge base for the panelview setup I find that I do not set the PLC/SCANNER type to CONTROLLOGIX but to a plc 5 processor type.
is this correct and if so which plc 5 processor do i choose being there are many to choose from in the drop down menu?
and if in the plc I mapped say
PV_WRITE_DATA (INT type) to FILE N7
and my array is 64 bits long i now address these bits in panel view as:
PLC --------------------> PANELVIEW
PV_WRITE_DATA[0].0 -------> N7:0/0
PV_WRITE_DATA[0].1 -------> N7:0/1
ETC...ETC...ETC
PV_WRITE_DATA[0].15-------> N7:0/15
SO NOW MY PANELVIEW BLOCK TRANSFERS ARE SET TO
ADDRESS: N7:0, MODE: WRITE, LENGTH: 64
ADDRESS: N7:100 MODE: READ, LENGHT:64
DOES THIS LOOK CORRECT?
ANY HELP IS APRECIATED AND WELCOME BEING THIS IS ANOTHER LEARNING EXPERIENCE FOR ME.
ETC...ETC...ETC
