ControlLogix: Is There a Hard Disk Drive Option?
Dec 2016
Southeast
134
Currently have a couple of redundant "PI Collector" desktop PCs gathering PLC data in case their respective PI Server goes down or reboots. They're in between the PLCs and the servers. Rockwell performed some maintenance on one Collector yesterday while the other was apparently *not* collecting data, and the result was 23 hours of lost PLC data!! Went for years without these "Collectors" without any real problem. PLC data went directly to Servers running PI. Since adding the "Collectors" in between, have lost data a couple of times now.
DCS has HDD circular buffer which solves this problem. Up to 3 or 4 days can be stored, but that includes doing collection based on trigger criteria downloaded from each application. Would be nice to have a similar arrangement on each PLC, but it's probably never done anywhere, right?
Hi - I'm a newbie to the PLC world but was recently asked if we could store more than the 2G that the CompactLogix 5370 allows by its max size SD...
1,353
Hello everyone, has anyone managed to communicate Twido with Controllogix using the Ethernet connection?
42
129
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
114
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
241
