ControlLogix l60MO Processor
jthornton
Jul 2002
Poplar Bluff, MO
295
Has anyone used the AB ControlLogix L60MO processor together with WonderWare to control a three axis servo system. Is there any gotcha's doing this? They want to use the WonderWare to store the recipes for each part made on the machine so the operator can just call up the part by the part number and run the batch. any thoughts are welcome
thanks
john
I haven't done it myself, but I do have a few thoughts on the matter....
You are probably not going to store the information for recipes in the wonderware.... That will be used to display recipe values, change recipes, and change individual recipe values when necessary. The recipes should be stored in an array in the contrologix processor, and then you will load the values into the "current running" array using wonderware tags linked to your part numbers. My experience has been with using(not setting up) a 13 axis contrologix system with a VersaView, so I don't have any Wonderware specific "gotcha's".
Hello everyone, has anyone managed to communicate Twido with Controllogix using the Ethernet connection?
33
124
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
114
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
241
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
236
