Convert PCB to PLC
msiami
Jul 2009
London
Any recommendations and suggestions for reverse engineering legacy PCB and converting to PLC system?
All we have is the physical equipment, the designs are long lost and we don't want to start from scratch.
Its not for a very complicated system. The 2 PCBs are 4" x 4" and 5" x 7". (as you can guess I'm know nothing about electronics, thus the lack of details!)
We are based in the UK, but we could send the stuff to the US etc. if that's more cost effective.
Essentially I would be grateful for any recommendations; experience of how best to go about this; approx. time scales and cost (i.e. is it 6 weeks and $10k, or 12 months and $100k?
More information required
The object of this is probably to achieve the same functionality of the PCB control with a PLC. So a functional/electrical description of the operation would be more helpful than pictures of the PCBs.
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
100
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
334
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,413
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
542
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
699
