Converting a decimal number to HEX.
NoName
Sep 2003
Domžale
273
Can I convert a decimal nubmer to HEX in step 7,and if it is,would you please guide me through it(wich function tu use,and so on...)
I have to send a HEX value to a motion control inverter.I cannot send a decimal value unfortunatley.The Decimal value is to be entered in a OP(C7 635), and then it should be converted and sent to the motion control inverter.
Thank you.
>Ales<
Do you need to send a STRING in hex?
16 or 32 bit integers/words have no actual differences between decimal and hex.
Decimal Integer 15 = Binary 0000 1111 = Hex 0F
Yes i need to send a string.
I've configured a inputfield in Protool,so that it send a double intiger to step7 and then this word is sent forward to the motion control.The sent word is distance in mm.And i think that it should work.
Thank you.I'll check back if there are any problems.
>Ales<
I am having problems expressing an ANALOG OUTPUT 16bit INT word (0-10V Proportional Valve Voltage) as a REAL decimal number. From my...
9,168
Well I am trying to cleanly convert a decimal value in a DINT to the corresponding bit in a different DINT So if I have the number 11 on in...
1,988
Do any of you Excel gurus know of a VB code or function that will convert ASCII text into it's decimal equivalent? I'm not VB savy at all. I...
5,830
We have an AB 1395 drive controlled by a PLC-5/40 via RIO. We are developing a monitoring computer using RSView32. This computer will poll the...
7,875
How can i convert negative decimal value(-100) to hexadecimal.
7,623
