CPU S7-300-313C Analog output not changing mA
sarfraz_jsr04
Jun 2017
jamshedpur
Hi guys, I have CPU S7-300-313C ( Cat No - 6ES7-313-5BE00-0AB0) DI24/DO16 and AI5/AO2.
when I am trying to configure and use the AO channel PQW connected with a valve positioner, facing error, it is not changing the output 4-20mA as per logical value, it is always giving 6mA.
I am using FC106 (Unscale) Block.
kindly suggest which FC block I should use.
I have doubt about analog output loop wiring, I need to know how many wires I need to connect for a 4-20mA current output. I guess only 2 would be enough. Are there anything i should care about?
I have searched the support site but unable to find relevent data (might be because of my pathetic search skills. )
so kindly provide any reference wiring diagram for AO chanel of CPU S7-300-313C
Did you done hardware setting for AO. I think it is set on voltage configuration.
regards,
Yes I have done Hardware configuration (I / 4..20mA), refer attache snapshot.
In AI/AO monitoring table it is showing some Error, Refer attachment.
I have also doubt about AO loop wiring, please share wiring diagram for S7-300-313C AO Channel, if any one have.
What terminals are you wired to
It should be 17 and 20 for AO1 and 19 and 20 for AO2
Also can you post a screen of the general tab for the AI5/AO2 I just want to make sure there is not a disable there.
And are you checking the output with a meter?
and finally what slot is your module in
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
134
Good day, Can you give me a link or a list of how built in i/o's have been distributed with the S7-300 CPU 313C. thanks in advance for your help
1,244
Hello, I am using step7 v5.5 and wincc flex 2008. I have created my PLC program have it working, but I am having trouble with my...
10,092
Dear all, any one can you please send me an example programme in S7 300 plc in which 2 analog inputs are read and compared with a preset value (...
14,349
Dear all ! I am trying to link CPU Sienmens S7-300 (CPU 313C) with an Idec touchscreen via CP340 (Siemens). I used the sample program of IDEC to...
3,964
