CRC Check 2's Compliment
MACCI
Dec 2003
Don't suppose anyone has written a CRC error check using 2's compliment in BASIC for use with TI 505-7101 BASIC Programming Module.. if this even sounds remotely familiar drop me a line, and i will touch base with you with more details. Cheers. J
The one that I think that you want is CRCC-CCITT (or CRC-CCITT) based on:
http://www.sea.siemens.com/autogen/docs/plc/505/manuals/560-8107-3.pdf
The poly that your would then want would be X16 + X12 + X5 + 1 (1021h):
http://www.aacomsystems.com/CC8110.pdf
Theory:
http://www.bbc.co.uk/rd/pubs/reports/1981-04.pdf
http://www.altera.com/literature/an/an049.pdf
Walk-through example:
http://www.joegeluso.com/software/articles/ccitt.htm
Example using a lookup table:
http://home.att.net/~jackklein/C_Unleashed/crcccitt.c
Short example (which crashed my browser. Drat, should have been doing this in Konq):
http://www.eagleairaust.com.au/code/crc16.htm
Pascal anyone? (for the Mac no less):
http://www.mactech.com/articles/mactech/Vol.09/09.04/CRC/
Forth? Ok, it's late:
http://www.forth-ev.de/VDimWeb/VD_0498/page17.htm
Try before you buy:
http://rcswww.urz.tu-dresden.de/~sr21/crc.html
On your own:
http://www.google.com/search?q=crc+ccitt&hl=en&lr=lang_en&ie=UTF-8&oe=UTF-8&start=10&sa=N
Enjoy,
John
Hello, i am connected l&t energy meter to PLC through RS485 in tia portal v15. i was reading values in plc. my problem is how to check crc 16 in...
1,707
Can anyone tell me how to monitor a db if the data changes? I want to restore data from the store db to destination db only if the information...
2,055
Hello Everyone, I'm trying to communicate with the SLC500 through Serial DF1 and I'm having some difficulties: 1st: I didn't quite get the...
4,290
Hi Am trying to get a Fx2n to communicate with a sampling machine via a Fx2n-232-BD board. The machine is Modbus RTU. Unfortunately I have run...
2,000
Hi, I'm setting up a new cell with a Fanuc R30iB and Compact Guardlogix 5380 PLC. I have gone through my robot setup as usual, but have not...
757
