Data logging dont start in RS view32
AB2005
Nov 2006
Lahore
320
Hi;
I have created a datalog file to log the values of some tags but problem facing that system is not creating Excel file. Actually values were being updated before malfunctioning of hard drive of PC but after installation of new HD and downloading of program, HMI is working fine but datalogging is not. Please see the below images of datalog set up and help how to fix the problem.
In "Start Up", the datalog file "Daily Prod" has already selected.
Did you configure data logging to start when RSView starts in the start up configuration (under system)? Or did you configure a macro to execute the datalogon command to start data logging and call that macro somewhere either on a screen or in an event? You will need one or the other.
From View: Help DataLogOn
DataLogOn <component>
Starts data logging for a specified data log model.
<component> is a relative or absolute reference to a data log model. If the model name has a space in it, enclose the name in quotes; for example, "Recipe Log".
Select the Data Logging check box and select a data log model in the Components tab of the HMI server's Properties dialog box, to start logging automatically when a project is started.
To stop logging, use the DataLogOff command. To create a new log file, use the DataLogNewFile command.
Data logging is already configured. Please see the attached image.
nformation for all.
I just deleted the old datalogging file setup. Created new one and found datalogging strated.
The data logger function was probably looking for your old hard drive. The new drive probably has a slighty different name and address.
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
88
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
97
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
318
Hi All, I am looking for recommendations for a data logging software package that can be used for a simple 1 PLC installation. The installation...
1,419
Hello all, I am working on a DA70A flex edge data logger. I am it communicating with a computer on the network. I can ping it and everything looks...
398
