Data Logging Setup
PortmanBlue
Dec 2010
Australia
Hi, I have a simple application which involves monitoring equipment voltage and current, logging this data and displaying the data as a trend. The data is to be retained for an amount of time, possibly months, to allow the trends to be reviewed. The data will need to be accessed remotely by 2-3 people via their PC.
To achieve this I was planning on using a Micro850 PLC with analogue input modules along with a C400 PanelView Component with a USB drive for data storage and FactoryTalk View SE to allow remote viewing of past and present data.
My query is if this would be a suitable setup for this application? My experience with data logging is limited so any input or alternatives would be appreciated.
AdvancedHMI is a zero cost option. It has a driver for the Micro850, a basic data logger, and a trending chart component (ChartBySampling)
I have done this with a Mitsi PLC and Bejers E1043 HMI.
Has USB, Networking, Trending. A webserver and more.
Thanks for the replies everyone, I will certainly look into these options.
I should mention that the only reason I was including the PanelView Component was to allow data logging, I've since become aware that an alternative to the PanelView Component and FactoryTalk View SE such as a Red Lion Data Station Plus with web server would be more suitable in terms of cost and application. Remote access through a website as suggested would also possibly be easier and less expensive than FactoryTalk View SE.
Hello all, I'm currently using TIA Portal v17 with a S7-1200 and a KTP-400 Basic HMI. I have a data log set up that begins logging various data...
1,203
Hardware is. S7-1500. Software is tia v15.1 Hey guys I'm trying to use the data logging to my mmc. I can get it to log the data. But only for one...
930
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
85
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
97
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
316
