Device Net niu issues
14all
Oct 2006
Vancouver
Hello... I have a Versamax syst with a devicenet niu card that includes some eds software for IC200DBI001 module. What does the software do, how can I load it and why can't I use the module without it?
Thanks for any information possible
Electronic Data Sheet (EDS) files are simply specially formatted text files that include all the information that a configuration software program will need to configure a DeviceNet node.
In your case, the VersaMax Network Interface Unit (NIU) acts as a DeviceNet slave. The EDS file will contain information about it's I/O connection sizes and any adjustable parameters in the device.
Your master device generally determines what sort of configuration software you'll use. If you're using Allen-Bradley masters, you use RSNetworx for DeviceNet. If you're using Think & Do, you use their configuration application. If you're using SST, you use the SST-DN3-CNF configuration console.
What's your master device ?
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
151
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
357
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
355
134
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
374
