DH-485 Printer for PV300 DH-485
SNK
May 2004
Toronto, Ontario
885
Does anyone know of a small printer device that can be networked with Allen Bradley DH-485?
I am looking at printing very small documents on typical Receipt Paper within a program I am currently writing using a AB PV300 and ML1200, networked with the NET-AIC module.
I was limited to space and costs, so I opted to the PV300 over the next larger model, which includes a printer port, (if anyone cares)
Any help appreciated, Thanks in advance.
If your willing to convert the RS 485 to RS 232 then Epson has a line of small cost effective ticket tape printers.
If your willing to convert the RS 485 to RS 232 then Epson has a line of small cost effective ticket tape printers. That will work over a serial port.
I am referring to AB DH-485 Protocol. It is not the same as RS-485. I need something that is compatible to DH-485 as a communication type.
Thanks for the responses....still looking....
To be honest with you I've never come across a rs 485 protocal printer. I've been dealing with printers for over 12 years now and have yet to see one that does RS485
I have an Allen Bradley Panelview 550. It was originally bought with RS232 DF1 communication and a printer port. I changed the firmwre to use as...
5,560
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
273
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
157
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
171
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
133
