digial input cable sizing
Please I want to know what is cable size (mm)reqiured for digtal input for 250 m cable length? 24 VDC is used
More infor needed. Which type of application is this? Isnt there any other option available? Meanwhile try using this voltage drop calculator.
Hope this helps.
Please can you help me I need to transmit two digital signal from electrical panel to PLC which is located 2km far from panel... I dont want to...
2,062
Hello All, After trying to transfer some field changes on the safety scanner microscan3, and verifying, the device is stuck at .... waiting for...
26
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
83
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
262
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
81
