Dissecting an EDS file for non-RSNetworx
Scott180zip
Oct 2008
Brunswick, OH
Here is a challenge:
I am using a i-7243D Gateway (DeviceNet to Modbus/TCP/IP) to pull in DeviceNet data from a VFD (Alvitar 71 - Schneider Electric). I only need limited information from the Drive (i.e. RUN/STOP/POWER/FAULT). The client wanted to save money and did not want to use an AllenBradley DeviceNet scanner. The Alvitar 71 instructions use RSNetWorx to pull in the device data. Unfortunately RSNetWorx does not read Modbus so I must import the data by setting up an ARRAY in the Gateway's ICP-DAS Configuration software. Has anyone had any experience in this procedure? I attached a bitmap showing an example EDS text file and the device configuration screen for the I-7243D Setup.
Any help would be much appreciated.
Here is a challenge: I am using a i-7243D Gateway (DeviceNet to Modbus/TCP/IP) to pull in DeviceNet data from a VFD (Alvitar 71 - Schneider...
2,538
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
81
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
189
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
248
By way of background, I've written an Ethernet/IP driver for one of our products and we're ultimately going to attempt to get it certified by...
263
