DL260 Comm Link through a dialup modem
AlecTek
Sep 2010
Vancouver
155
A dial in ethernet switch modem (SLX-5MS-MDM-1) connects PLC DL260, HMI EA7, and a computer through ethernet. ip address would be 192.168.0.10, 11, 12, 13.
I use my laptop (192.168.0.14) to dial in the switch with a username and password. There are two problems:
1) I configured Windows Xp a new network connection with a modem, and I can connect to the switch which says TCP/IP connects successfully, but IPX/SPX not. At this point, I tried to connfigure the DSLaunch a comm. link, but I don't know how to let the Comm.link use the existing and already in communication link.
2) If I don't dial manually. I configure the Comm. link in DSLaunch, but there is no where I can set the username and password, so I have no clue how it can dial in itself.
Hello everyone, I got stuck on Communication with DL06/DL260 (H0_ECOM or ECOM100) through Modbus TCP. To make it simple I only read holding...
1,448
OK, I'm having trouble understanding correct addressing to read data from the MB-Gateway Automatic Read registers. I am reading data from the MB...
1,665
Well slowly picking up the Directsoft and DL260. i have a problem with the analog in. i have 12 mA on input 0 which should be V400. i don't see...
1,794
i must be as thick as mud, but i'm still scratching my head on the memory mapping. here's what i have: Slot 0 = ECOM Slot 1 = 8ch analog in...
2,074
I understand how the system works: EA7 (Cmore) <--RS232--> DL260 (PLC) <--Ethernet--> LookoutDirect 4 but I have no idea if its possible...
1,844
