Dlog Function not working with multiple string
Ramsri
Apr 2014
coimbatore
40
Hi All,
I had enough experience in data logging with variables. But when i try to create a datalog with Multiple string values along with Real, D-word Variables in Ag31 V3.0, V11 software i didn't get the result. Whenever i do the same with AG40 series PLC's on V13 software i get the data logs.
Can some one help on this issue?
P.S : Data log create Block indicated 16#7000 whenever created with string option in V11.
Ram
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
139
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,112
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
448
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
308
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
710
