Does Momentum support modem
tabrez
Sep 2004
aurangabad
27
Hi Every Body
Here I M Once again ,just a query about momentum, i want to use momentum for my RTU apllication , does it support modem if yes then which one and how , i mean modicon or other.........plz if possible give me details ...............
I have one customer who regularly uses Modicon processors, including Momentum, with MultiTech modems. I am not familiar with the exact set up but I do know he has used both the 984LL XMIT and the Concept XXMIT functions.
J
Using an analog input, what does one put into the totalizer block to make it count based on the 4..20ma at channel 1 need a BOOLEAN output when...
4,460
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
46
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
126
