Lemming Member L Join Date Oct 2004 Location PalmerstonNorth Posts 332 Mar 21, 2014 #16 It's been said, the pump is a proportional dose pump... All he needs to do is figure out how to drive the dose rate appropriate to the process...
Lancie1 Lifetime Supporting Member Join Date Jul 2003 Location Alabama Posts 9,999 Mar 21, 2014 #17 Yes, simply use a PLC analog output to send a digital number to the variable speed Grudnfos Dosing pump. The Output has to be scaled to produce a range of numbers from the Minimum to the Maximum numbers of the dosing pump.
