Downloading to PanelView 600
rwy34ils
Mar 2009
Edmonton, Alberta
73
I have a PanelView 600, 2711-T6C20-L1 and PanelBuilder32. The panel has Ethernet and printer ports.
I am trying to download to the panel. It is my first time doing this. I am using the printer port on the panel and com 4 on my PC. I have set the printer to 'disabled' on the panel. The baud rate, etc. matches. No way can I get them communicating. Does the PanelView communicate through RSLinx for this? Where do I set the com port to 4 in the PanelBuilder?
Lost & confused...
Thanks!!!!!
Update...The PanelBuilder seems to be communicating with the panel. If I go into RSWho in the RSLinx, I can see the PV600 panel connected.
The problem is that if I click the 'Download'or 'Upload' menu items, I just get a warning message pop-up that says ERROR, with a large exclamation point.
Is it a error or warning, What does the error say.
Does it look like this ( see pic below).
Can you provide us with a screen shot?
Or post your PanelBuilder32 program? Zip it first then post.
Thanks Mickey.
No, it doesn't have any kind of message. In fact, it doesn't say Warning or Error. I just get the exclamation mark inside the yellow triangle and an OK botton to click on. All I have in the PanelBuilder program is one test screen with just a bit of text--nothing else.
When I click OK, the pop-up warning screen goes away, that's all. No, I haven't tried the file transfer utility. I don't know how to do that. This is all new to me and I'm finding the user manuals aren't a whole lot of help. I have done many other brands of HMI panels, but never the AB ones.
First, go to File...Workstation Setup and make sure you have the checkbox selected that says "Automatically use RSLinx If available"
It may be that you are trying to use the direct driver in PB32 while RSLinx already has the comm port tied up...
That's just a WAG though...
Paul
More on the Transfer utility below
  • WINPFT.doc
Okay, try shutting down RSLinx first and make sure there is nothing else (other software) using your comm ports. Then if you still get the error trying to get to workstation setup, I guess it might be time to re-install PB32...
Paul
Good advice. I just installed PanelBuilder on my other computer and it works properly---no error messages. I'll try re-installing it on this laptop & let you know how it works....
Problem solved. I reinstalled the PanelBuilder and it works correctly now. Amazing how many hours you can waste on something simple!!!
Thanks to Mickey and Paul for your much appreciated help!!!
Your Welcome!
Also, once you get a normal application built up, you will find it much easier to transfer it using the ethernet port or a PMCIA ATA memory card...
The serial method is quite slow...
Paul
I'm no longer struggling forward but have come to a stop. I am trying to download a Panelbuilder32 application to a PanelView Plus 600. I've...
5,350
Panelview 600 (2711-B6C8) has DH+ port and RS232 Printing port. I don't have DH+ capabilities from development PC. I believe I can download to...
4,456
I'm new to this, and I'm trying to download a program to a Panelview 600 I've got Panelbuilder 32, a 1747 UIC and it's connected to the 600 with...
3,782
I have a SLC 5/03 and I connect vie 1747 UIC cable via ethernet plug in. The panelview 600 PN is - 2711-T6C16L1 It is only TOUCH screen. I had...
2,622
Good Afternoon , I have a Panelview Plus 7 Performance HMI. I made some screen changes and created another runtime. I downloaded to the...
2,484
