E-terminal E1071 to laptop via usb serial cable
atreloar
Jun 2006
adelaide
42
E-1071 com2 rs232 cab5 cable to laptop usb serial coverter cable
problem is laptop will communicate with all melsec plc's via usb/rs232 cable no problem but will not communicate with the E1071 ! any ideas as to problem. the same cabling communicates with E610 terminal ok!!!!!!
Hi Atrelor,
The problem is not the converter, the problem is the cable! The RS232-port is changed on E1000-terminals compared to old E-series (pin 2 and 3 are switched). You will need to use a CAB30 (I've attached a cable description).
//Supporter
Hello! Got an E1071 operationterminal working with an FX1N. Works good. I have a little problem i want to be able to backup everything...
2,455
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
119
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
235
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
162
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
964
