Ethernet to 232 ASCII
Oct 2012
Richfield, Ohio
465
I have a KEB C6 Smart PLC that does not have a serial port, and will need to talk to 2 devices that only have RS-232 ports. It is a basic ASCII protocol. I can do ASCII messaging out of the Ethernet port of the PLC, but need some kind of converter to change to RS-232. A lot of the converters on the market expect a PC to be involved somehow. Has anyone done something like this? Any recommendations?
I remember years ago doing a TCP Socket transmission of bytes, and the Digi One IAP Ethernet/Serial device would strip the TCP encapsulation, leaving only serial data on the serial port. Basically the complete ASCII strings had to be sent by the controller, and the IAP device would strip off the TCP information. You have to identify the start/stop ASCII characters in the IAP, so it would know the begin and end of a serial stream of data.
https://www.digi.com/products/serial-servers/industrial-hardened-serial-servers/digioneiapfamily
I have had really good luck over the years with Phoenix Contacts FL-COM servers.
OK AutoMax, who are you and how do you know me?
I have used the Anybus Ethernet/IP to Profinet gateway before. Worked pretty well. I will see what their options are for Ethernet to 232.
Does any one knows if micrologix 1100 would be a good choice to receive ascii string characters by Ethernet port and forward it using rs232 port...
5,517
Hey Everyone, I need to Interface Ignition SCADA ethernet network to an Allen Bradley SLC5/04 Serial RS232 DF1. Has anyone out there found a low...
1,025
has anyone used an anybus module or some sort of serial to ethernet converter with a control logix plc? If so how did you translate/parce specific...
3,562
Good Afternoon colleagues! I need to do data acquisition for my MICROLOGIX 1200 but, I already using channel 0 to communicate with HMI and...
4,909
Okay here we go. I am new to this and I need to know the easiest method to mate an Micrologix 1100 to and Automation Direct with RS232. I have a...
2,840
