ez automation calender set up
roni
May 2015
INDIA
37
This time i need a help on below issues.
1. I want to set the date and time from PLC (now it is possible to take from HMI)
2. I want to set a periodic operation through hmi. It needs a calendar to pop up and need to set an advance date (Year, Month, Date and Time etc.)
3. Need to set up a sunlight save program in the PLC and HMI.
Kindly refer the attached program for date, time and sunlight savings, (its not working properly)
waiting a reply
thanks in advance,
Rons
The program that you posted had the real time clock in it. Can you monitor it online and see the current date and time?
Can you manually set the date and time by the same method as the program?
Regards,
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
63
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
95
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
222
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
141
