FactoryTalk View Expression editor limit
MartyMaucher
May 2014
Pensacola
91
I have apparently hit about a 980 character limit in the FT View ME String expression editor. I need to fit about 1 more line if I could. Is there a way to use an abbreviation for tag names or some other solution to this?
OK, it's in the help file, "up to 999 characters". I suppose I could shorten the tag shortcut name (NearmanFile) to get enough space to fit what I need.
Just a rant... but what kind of *&%@! software limits code area to under 1k characters?
1) Create the tags in the tag database. Short names. Done.
Direct access tags are just plain evil.
2) Instead of doing what you are, use a local message display for your strings. Then they only need an index number, which can be generated in the PLC.
This issue happens occasionally but is getting annoying...I cant click what I said in the title randomly. Sometimes it works sometimes it doesnt...
1,596
Hello, I am fairly new to AB PLC and HMI. I am using Factorytalk View to create an HMI application. While using Macros, I wanted to create a...
2,410
Using PV6+, FactoryTalk View Studio to talk with PLC The expression error that keeps popping up are tag/10 or tag/100 (which doesn't make sense)...
2,913
I am using multi state color animation. My current expression is this. SEVERITYY is an Analog tag. When i set my tag value to 750 and above i...
5,489
Good Morning , I have a delicate SLC 5/05 system that I would rather not make any changes to the PLC. I have a Panelview Plus and I would...
4,217
