FactoryTalk View ME old mer Revs
michev
Nov 2014
VA
What is the latest version of FT View ME that will create a 3.0 runtime file with security accounts?
I guess maybe I should clarify a little bit. I have an application I uploaded from an older PanelView Plus running FW 3.0. My FactoryTalk View ME is 8.1. I need to downgrade/reinstall an older version of FactoryTalk to allow me to produce a 3.0 runtime with security accounts. I don't want to flash the PanelView due to the customer's ability to connect & modify to newer firmware.
I am 95% sure that FTView View ME 6.0 lets you create a 3.0 file
50% sure that FTView ME 7.0 lets you create a 3.0 file
FTView 8.0 and newer definitely will NOT create 3.0 file.
And just as a side note, Rockwell seems to have dropped the existence of version 3.0
It was not a good release. If your PanelView runs fine on 3.0, okay. But if you have any issues at all, then I highly encourage an upgrade to 3.2 (which then also lets you use the newer FTView Studio to build those files).
I found a Tech bulletin that eluded to rev 5.1 being the magic number. This seems to work (not fully tested). There was a bit of downgrading of other supporting programs to make FTV 5.10 work. Problems I have encountered so far include setting up the Runtime Security and the Communications while offline.
If I find this info to be incorrect, I'll post an update, otherwise 5.10 produced the needed 3.0 Runtime.
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
152
Good Morning , I have a customer that has an old Panelview and an obsolete 1769-L35E processer . I need to replace the HMI , and I'm changing...
1,161
Doing some consulting work using factorytalk view studio and RSLogix5000. We set up alarms for the system a while ago and they work fine, as do...
3,668
I'm wondering if anyone here is running FactoryTalk View ME version 10 and has tried importing old 32 bit HMI project archive files, say going...
3,603
Just installed the new Factorytalk View. Have imported a project and upgraded it from V6.1 to 8. All my bold text de-bolded. The bold, italics and...
2,705
