FactoryTalk View SE 5.0
Sep 2008
Cidra
I'm currently working with a technical assessment to decide a system migration to FactoryTalk View SE 5.0 vs FactoryTalk View SE 4.0
I'm looking for any particular product issue (of any of the mentioned versions) that I should be aware off. Your input will be appreciated.
If you use VBA Code at all, most particularly, passing parameters back and forth between displays, FTView 5.0 is broken.
Other than that, no real issues with 5.0. Rockwell did drop the August 04 Patch roll-up for View 5, due to some compatibility issues with un-patched stations (no kidding!, but why would you not patch all connected units in an application?).
Really though, the only bad problem I have with 5.0 is the VBA. It takes a LOT of tweaking to get it functioning. Alarms and Events is almost worth losing some VBA functionality though.
The system that I'm planning to migrate use a lot of VBA for users security purpose and it continuosly pass parameters between displays.
Do you know if Rockwell has a documented technote on how to fix the VBA issue?
RSView SE/FactoryTalk View SE
RSView SE/FactoryTalk View SE is the most unreliable and unstable HMI software ever on the market. We had extremely bad experience with this product.
Thexman - you're quite the lurker. Registered a year and 7 months ago and you're first and only post so far knocks a product. Welcome, though. Perhaps you had a good experience with whatever you replaced that product with?
So far I had only one reply about the goods and bads of FTView 5.0
Do you have any other feedback about this product?
I will appreciate any feedback about it, thanks a lot.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
195
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
133
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
179
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
124
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
203
