FactoryTalk View SE 5.0
Sep 2008
Cidra
I'm currently working with a technical assessment to decide a system migration to FactoryTalk View SE 5.0 vs FactoryTalk View SE 4.0
I'm looking for any particular product issue (of any of the mentioned versions) that I should be aware off. Your input will be appreciated.
If you use VBA Code at all, most particularly, passing parameters back and forth between displays, FTView 5.0 is broken.
Other than that, no real issues with 5.0. Rockwell did drop the August 04 Patch roll-up for View 5, due to some compatibility issues with un-patched stations (no kidding!, but why would you not patch all connected units in an application?).
Really though, the only bad problem I have with 5.0 is the VBA. It takes a LOT of tweaking to get it functioning. Alarms and Events is almost worth losing some VBA functionality though.
The system that I'm planning to migrate use a lot of VBA for users security purpose and it continuosly pass parameters between displays.
Do you know if Rockwell has a documented technote on how to fix the VBA issue?
RSView SE/FactoryTalk View SE
RSView SE/FactoryTalk View SE is the most unreliable and unstable HMI software ever on the market. We had extremely bad experience with this product.
Thexman - you're quite the lurker. Registered a year and 7 months ago and you're first and only post so far knocks a product. Welcome, though. Perhaps you had a good experience with whatever you replaced that product with?
So far I had only one reply about the goods and bads of FTView 5.0
Do you have any other feedback about this product?
I will appreciate any feedback about it, thanks a lot.
As the title says, all of the client HMIs at the plant freeze up for about 5-10 minutes everytime I or a vendor make new routines or new tags in...
44
Hello, I want to connect the Factorytalkview ME with rslogix500 to see the live response of HMI buttons in Rslogix500 ladder code . I am using PLC...
115
139
Hi. I need to create several alarm servers in an application, but first I need to know if there is any impact on communication, or if more...
96
Hello all, I'm having trouble opening an application. After clicking open I'm prompted to login and after putting in username & password it...
97
