FactoryTalk View Studio ME Test Application
skeleton_bob
May 2013
Coventry
Until recently I was using the Test Application feature of FTVSME (6.10.00 on Windows 7 32-bit) just fine. It would simply run the application on my laptop screen, no questions asked.
Now, for reasons unknown, when I do this it opens FactoryTalk View ME Station and makes me load an application by selecting a runtime file. I try to but it just moans that it can't load it and offers no explanation why.
What have I done? How can I make it go back to how it used to be (preferably without uninstalling everything and reformatting my hard drive)?
Assuming Windows 7 or 8, are you launching Studio as an administrator? I had the issue earlier this year and that solved my problem.
I tried opening both Studio and Station as an administrator, neither made any difference.
I even tried uninstalling FTVSME and re-installing, but this didn't help either.
In something approaching desperation I called Rockwell tech support, and they gave me a detailed and laborious uninstallation procedure to properly clear out all the file and registry debris that Rockwell leave behind when merely removing FTVSME via Windows. Then re-install again.
This would appear to have worked. Seems I committed the cardinal sin of:
Installing Some More Software.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
142
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
265
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
702
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
629
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
463
