FactoryTalk View Studio ME Test Application
skeleton_bob
May 2013
Coventry
Until recently I was using the Test Application feature of FTVSME (6.10.00 on Windows 7 32-bit) just fine. It would simply run the application on my laptop screen, no questions asked.
Now, for reasons unknown, when I do this it opens FactoryTalk View ME Station and makes me load an application by selecting a runtime file. I try to but it just moans that it can't load it and offers no explanation why.
What have I done? How can I make it go back to how it used to be (preferably without uninstalling everything and reformatting my hard drive)?
Assuming Windows 7 or 8, are you launching Studio as an administrator? I had the issue earlier this year and that solved my problem.
I tried opening both Studio and Station as an administrator, neither made any difference.
I even tried uninstalling FTVSME and re-installing, but this didn't help either.
In something approaching desperation I called Rockwell tech support, and they gave me a detailed and laborious uninstallation procedure to properly clear out all the file and registry debris that Rockwell leave behind when merely removing FTVSME via Windows. Then re-install again.
This would appear to have worked. Seems I committed the cardinal sin of:
Installing Some More Software.
As the title says, all of the client HMIs at the plant freeze up for about 5-10 minutes everytime I or a vendor make new routines or new tags in...
60
141
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
184
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
297
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
940
