FactoryTalkView-SE Activex Problem
Jun 2005
54
Hello All,
We are using FactoryTalkView-SE Ver-5.0 CPR9.
We need to use Microsoft FlexGrid Control ActiveX.
It is available in Objects > ActiveX dropdown. But when used on graphics it gives an error Activation was not found". It seems that this object works if VB6.0 is installed on the PC. But the customer donot want me to install VB on his PC.
Another Activex I found was VideoSoft FlexGrid Control available when I installed FactoryTalk Transaction Manager CD that comes with FTView-Studio package. This object is ok with me. But the problem is that during run time the ScrollBar for this object doesnot work. I did check all the properties and enabled ScrollBar property. Even from VBA script I did enable the ScrollBar property. But didnot work.
Have you guys faced this problem anytime?
Any suggestions / solutions? Are there any patches to be installed?
Your suggestions are highly appreciated!!
Regards,
Pramod
I found this on the A-B knowledgebase.
Many third party (like Microsoft) ActiveX controls may only be available through a development environment such as Visual Studio or Office Developer. One example is the Microsoft FlexGrid Control 6.0. The control that appears in Studio is only for runtime applications and cannot be used in the Rockwell development environment, nor will it work in a Microsoft Office application.
If possible, when this error is encountered attempt to place the ActiveX into an Office application. If the same error appears, then the control cannot be used in the RSView or FactoryTalk View applications.
Mark is correct. ActiveX Controls are normally installed (by the thousands) everytime a program is installed on a Windows PC, BUT only the RUN-TIME component is installed.
In order to use a control in a development environment, you must have a license (and often, additional files).
It depends entirely on the control provider, there are a few levels:
Free
Licensed Development, Free Runtime
Licensed Development, Licensed Runtime
Free Development, Licensed Runtime
I am trying to open an activeX object to display a third party application. Basically I have to use an activex VNC Viewer to look at my third...
4,805
I'd like to embed a Real VNC application (I'm running a third party app), into an existing window in FactoryTalkView SE. I've never attempted this...
5,751
I am developing application in FactoryTalkView SE and I am using third party ActiveX symbol library from Iocomp. Problem with those symbols is...
1,710
I just converted an existing application from RSView32 to FactoryTalkView SE. In RSView32, the Datalog was made in a *.DBF file. There was...
71
Hello Friends I have 2 languages in my app, en-US, es-MX. I need to send CurrentLanguage to PLC, I am trying with Macro in Global Connections...
181
