Fanuc 90-30
usfacilities
Dec 2022
Philadelphia
I just replaced a coprocessor module and it will not go back to run. I have read all the solutions, but I can not find the Versa Pro software to download. Can anyone help?? PLEASE!!
To what does the word "it" refer, the PLC or the coprocessor module? Why did you feel you needed to replace the coprocessor module? Was the PLC running before you replaced the coprocessor? As far as I know, VersaPro software is not available as a free download anywhere. I think your best approach might be to call in a local integrator with GE Fanuc experience. You could also try contacting Advent. They used to be a GE Fanuc distributor in your area.
http://adventelect.com/
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
47
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
123
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
118
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
190
