fault indicator
Jul 2016
california
Hello everyone,
I need help to write a program that will show a fault using an led indicator.
Using an input as a trigger, it will turn on or latch an output indicator (green) if if it doesn't it will turn on or latch in indicator (red). Thank you in advance.
Welcome to the forum.
In general, people here are very willing to go out of their way to help people with what they are stuck on. That's why a lot of people are here, to help. Out of respect for the people that are willing to help you, you should put in a little effort yourself. Show us what you have tried and what exactly you are stuck on with this exercise and I have no doubt people will help you with it. If you can't show that you've made any attempt then I'm afraid that people will put in the same effort that you have, nothing...
So what specifically do you need help with? You should also mention the hardware that you are working with.
edit: I guess for some other advice, draw yourself a schematic. Write a sequence of events. Make a list of the inputs and outputs you will be working with. These activities will help you think through the task at hand.
Start by getting use to logic instruction
'A' = input
'B' = output GREEN
'C' = output RED
if 'A' is 'ON' then
Output 'B' is 'ON' (green Indicator)
if 'A' is 'OFF' then
Output 'C' is 'ON' (red Indicator)
you have mentioned more but your detail regarding latching is incomplete
search this Forum for Flip Flop or Toggle to help further
I Know 'dmroeder' has, like me, made many posts on this before
Hi everyone, I have a new Rx3i I installed on a line. The MAIN program has an indicator for CPU health activated as good so long as %SC09 is OFF...
1,200
I have 6 powerflex drives, two encoders and one 1734-ADN point IO rack on devicenet network connected to controllogix processor. There are 60...
3,348
Hello Software: RSLogix 5000 V.17 I am programming a conveyor system. Whenever a limit switch trips, the motor stops and I need the XIC...
12,761
can you please help me :site: i have this problem with my CPU CPU 416-2DP _ HW INTF: indicator LED RED Continuous EXTF: indicator LED...
10,202
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
84
