Fault question
fatd132
Nov 2014
louisiana
Hello,
I got an alarm - "Specialty I/O module in slot 4 has not responded to a lock shared memory command within the required time limit" - my first thought is to change out the card and see what happens. I have ordered the card and waiting till it arrives. If I clear the alarm the plant will run for a few hours then faults again. Is there any other ideas I should try?
so, let me guess from your vague post 🔨
..............RSLogix500.
Is it an SLC?
Is it a Micrologix PLC?
What is the specialty module?
What is connected to the module?
Does it have power?
What other I/O modules are connected and are they all working?
Can you remove said I/O modules and leave only the "faulty" one to test it?
Could be the I/O module needs replaced...but you need a spare for that....
Is there a problem with the power supply, you could replace the power supply if you have a spare.
Also, check for bad grounding. Noise could be entering the backplane and messing with processor comms to the I/O. Specialty modules are more complex, so more sensitive to this issue.
What is the IO module in slot 4?
A specialty module generally includes things like the Basic Module, or some other module that has an onboard processor and communicates to the main processor with M files, and require programming or configuration of their own.
One of the L62 faulted last week. First time I seen one of this in my many years of working with ControlLogix. Rockwell seems to take this...
1,786
Hello folks, This question is regarding a ML 1200 with a single expansion module, 1762-IF2OF2 (2 channel in, 2 channel out analog module). The...
2,009
Hi, The scenario: The system has been working fine for many years. There is an intermittent issue somewhere. I have yet to look for error...
1,196
I have a processor 545-1104 giving me trouble. I pulled the battery and let it sit for 15 mins to clear the memory and now when i try and download...
1,479
