ML 1200 Fault Question
bawaller
Feb 2012
Virginia
21
Hello folks,
This question is regarding a ML 1200 with a single expansion module, 1762-IF2OF2 (2 channel in, 2 channel out analog module).
The system was working great right up until it stopped working (2009 to yesterday).
The Major Error Halt bit S:1/13 is set
Major Error S:6 = 179h
Error description: Expansion I/O module 1 generated an error
Normally I am not a "parts swapper" but I'm short on time, so I was thinking about doing just that. Thought I'd run it by the experts though. Any thoughts?
Thanks a bunch everyone!
Byron
Yep, probably a dead card. A MLX will fault when a card fails unless you disable that. I would swap it out, hope nothing else breaks for the rest of the day and try to have a good weekend!
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
509
Hello, I have a Micrologix 1200 1762-L24BXB PLC and as soon as I power it up with nothing connected to it, the power LED and the fault LED both...
3,743
I have a 1200 C displaying the Fault light . With no additional I/O connected I cannot clear it. I cannot connect to it with the fault existing ...
2,246
Hi friends... I have a problem with my plc micrologix 1200 mod 1762l24awa today has a fault and i cant errased... the fault said...THIS IS A USER...
4,184
System is an IPC547D running GRAPH in WinAC RTX. Six S7-1200 (CPU 1215C) running a little code for manual operations, but mostly running as...
7,998
