First In First Out and Sequencing
jerkss
Nov 2010
malaysia
Hi all,
I'm new to the PLC world and i'm currently using Schneider Electric Unity Pro XL software. I need advice or sample programming on the problem below.
there are 3 demand and 3 pump (Pump A, B and C). Each demand will start 1 pump and if there is 2nd demand coming in, then the 2nd pump will turn on. If one of the demand is turn off, then the first pump will turn off and then if the 2nd demand is turn off, then the 2nd pump will turn off, following the FIFO rule. Then, if there is new demand coming in, the demand will turn on Pump B instead of Pump A or C.
Anyone have idea on how to write it?
Attach is my program in DFB
http://www.4shared.com/file/SEJKqBjU/test1.html
Please help...
use rising edges of run feedbacks to set internal bits giving you indication which pump was started first, second, and third. This way you will know which pump must start or stop next
counting running time can be a wise idea too
you start the pump with the lowest life runtime and stop the one with the higher actual runtime
thanks for reply,
meaning, taking the rising edge on which pump to start first to determine the next pump to be start..
thanks
Does anyone have sample logic with conveyors that start and stop according to product on the line?
115
Hello, I am struggling to figure out some logic. I have an analog pressure sensor coming into the PLC and would like to have multiple timing...
165
One of my customers builds equipment with a MicroLogix 1100 using a program I wrote some years ago. Now he wants to transition to a Micro 820...
1,863
Well Gentlemen, once again, I am trying to figure out how to do something in Logix, and I cannot seem to get it to work like all the YouTube...
2,949
I need to make a sequence of lights flash on and off in automation studios using AB PLC. I have to use timers and counters. The required sequence...
51
13,593
