Flex I/O fault
Phil78
Apr 2018
Minnesota
So I am working with this system and I have some remote I/O. its connected with a 1794-AENT. At the end of that rack I have an analog card 1794-IF4I/A. About once every three months I am getting a fault on it.
It seems like the card is some how not recognized anymore. Anyone ever run into this before?
attached a pic of the module info screen
system is running rslogix 5000.
I have nightmares about trying to keep FlexIO racks connected.
Unplug the modules, and re-seat all of the module base interconnects.... they seem to get stupid often with even the slightest vibration.
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
So our Powerflex 525's are set up to allow REMOTE operation from PLC through network. But if network is lost we want to be able to run in LOCAL...
572
Hello, guys I am having an issue with Pflex 755, when it is stopping the motor, it is going on fault 9 " Transistor Over Temp". Has anyone dealt...
483
I recognize that I need to factory reset the drive and that P053 is my ticket. Problem statement: I can't get passed the fault display to get to...
1,461
Hello. We use AB PowerFlex 7000 drives in a pump station. The operator just called to report a fault on one drive: "STATUS: Faulted" "FAULT: DI...
654
