Flex IO over Devicenet
Abdul03
Jun 2012
England
77
Hi Guys,
I have a small concern regarding Flex IO 1794-IE12 module. This module is connected over devicenet and communicating with the controllogix5000 L61 controller. I can see that the flex IO module is on the devicenet network. However, I connot able read data from the Flex IO.
One thing I would like to bring to your attention that the OK LED on the FLEX IO is "Blinking Green". I have tried everything I can, but still no use. Any suggestion will be much appreciated.
Thank you,
Hi
Have you the flex module in ye scan List and have does the Devicenet card display that it is in run mode.
You could try to disconnect the device net plug on the flex module and see does the device net card display any errors
Donnchadh
Thank you for the reply,
Yes the module appears in the scanlist and I can also see that the devicenet card display Run mode. However, I didn't check what happens when I disconnect the devicenet plug from the flex IO. I will let you know once I try this.
Thank you once again.
Something i ran into that has me stumped, hopefully someone can explain. I have powerflex 70's connected to a L7 cpu using a 1788-en2dn. The...
1,363
Hello, I am looking for some information on converting a Flex IO (1794-ADN) which is device net to an Ethernet/Ip Flex IO module like an AENT...
430
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,180
Hi all I am working on a retrofit project. There is one backup pump with Powerflex 753 drive controlled by 2 different PLCs(one 1756-L63 ,one...
1,540
I'm having a strange issue where the operator can input a desired speed in 0-110%, and the scaling will correctly translate that in Hertz to the...
2,293
