Floating point +31.1 not working
Can you tell the forum what PLC you are using and post a snapshot of the rung.
Or post the program if you can. Zip it first. Tell us which rung is the problem.
I need to check an axis actual travel position, and to compare it to the master travel position. To do this I have to multiply the axis travel...
2,573
We have AOIs for projects, which handle material dosing (by hand or by pipes and pumps), obviously they have comparison between setpoint and...
50
14,231
Hi eveyone. I need transfer signal from system 1 to DCS via modbus. System 1 only can send 32 bit floating point. DCS receive 16 bit integer. How...
20
10,634
Hi, In my ladder logic, I've got a data register D60 whose value is -0.001 (when using monitor mode to see values). D406 is 0.250. But then...
1,312
Hi, can anybody tell that how can we move floating point data from one Regiter to another register in Fatek PLC.?
1,555
