FTV Studio Custom Keyboard
fish00cake
Oct 2015
australia
Hi all,
Using FTV studio 8 on windows 7 touchscreen monitor. I want a large on-screen keyboard for touch screen typing logins and notes.
I would like the keyboard to be displayed and locked into a specific position. (100 px above the bottom of the screen).
Options I have considered:
1. Using default rockwell keyboards. Problem: keyboard is too small for gloved hand to type accurately.
2. Use built in Microsoft on-screen keyboard. Problem: windows key button poses a security issue and allows users too much access. Third party keyboard designer software may be an option. Any suggestions?
3. Build custom keyboard inside of FTV studio.
3.1: Use popup display and the standard rockwell built-in login functionality.
Problem: login box does not allow other displays to have focus, so we can't type in text via a separate display.
3.2: Use popup display and custom username/pw string input tags. A 'log me in' button will push these values into the "login [operator] [password]".
Problem: I can't pass the string data to the login function.
I am using code syntax: Login temp_username temp_pw
where temp_username and temp_pw are tags. Can someone check my syntax?
Also, is there a security issue with this method? Maybe bad practice as login/pw is stored as an unsecured tag somewhere...​
Tried searching these forums, the closest I could get to is this unresolved thread:
http://www.plctalk.net/qanda/showthread.php?t=4645
Not much you can do.
Rockwell is "Promising" a "New Version", that "Should Have Enhanced keyboard functionality for Touch Screens" sometime in late 2016, or maybe 2017.
Your second best bet is to completely roll your own keyboard, as an OCX component. About 2 decades ago, someone at Rockwell realized that the numeric keypad was horrible, and did an OCX for that, but only numeric. Rockwell probably fired that person for actually creating something useful for the HMI software.
The first best bet (and one I wish I could do here) would be to completely toss out any Rockwell HMI 'Solution'.
Do you know if there is something new on this topic?
Even on Version 10 of FTV SE its the same old Keyboard, and we have 2018.
I'm still using "osk.exe" from Windows or the "TabTip.exe".
Edit: These ones looks good http://www.virtual-keyboard.com/Features/Download/Download_keyboards/download_keyboards.html
And only 15$. Does anyone have experience if they work well in FTV SE?
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
132
Hi all, I have FTV v13 installed on my VM. I made an ME application and exported it in v11, as that's the version being used on the Panelviews at...
407
Hello Friends, I want to log FTV Studio SE alarms and event data into a oracle 12c database and as i checked the by default windows in FTAE...
825
Just "upgraded" from v12 to v13. I've noticed that the diagnostic list messages are not nearly as descriptive. In the past, I'd get something...
596
When I create a line in FTV Studio ME (v13 CPR9 SR13 - Patch 17 Build 413) and try to change the line style to anything but "Solid" it just...
1,240
