FTView - Can't start software
rQx
Oct 2010
Trelleborg
1,051
I have succesfully started the software before. I took my laptop home to do some programing/testing. Now when I start it it just pops up this message and then the application is closed. Any suggestions? I haven't got the DVD in my DVD reader but that can hardly be the reason can it? One time it came past this "windows loading screen" but then after a while (2min) the program closed suddenly again.
do you use wireless or did you use wireless in work to register.we had a similiar issue because it was looking for the server it had been registered with
I used the Disk serial number for the activation, but I was on a wireless network when I registered.
we found for it to work we had to connect to the server initially when started then we could disconnect from the server once it was running
Hi, How can I make a FTView SE application truly autostart with Windows? I want the HMI the operator should see autostart, not the client wizard...
3,445
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
189
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
240
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
102
