FTView Datalogging to SQL Express. How to purge database
Jul 2007
Kiruna
600
Hi all,
I am logging data via ODBC to a 2008 RS SQL express database. In FTView File Management I have set it up to purge record after 6 months. This is not working and my DB has now reached its limits.
Has anyone seen this before? Does it actually work or must I handle the purging externally via a stored procedure or scripting?
Thanks in advance.
Trevor
Hi
I maybe out of date but i recall you cannot purge the empty records unless the database is closed.
You can clean out old records by using running an SQL statement every now and then, for instance in the task scheduler in Windows. You can do this on the fly, so no need to shut anything down.
Code:
DELETE FROM Table_name
WHERE Date_column < DATEADD(mm,-6,GETDATE())
SQL Express is just a standard database from Microsoft. A free, scaled down version of their SQL server with some limitations on storage and memory use.
Hi Pete
Thanks for that info. I tried about 10 yrs ago and found i could delete the records but not 'compact' the database to removed the null entries when it was open
I see this a lot as we generate a LOT of data. In SQL express you can not scheudle this automatically with the database tools, in the full version you can. We end up having to manually backup, compress, and delete old records - on a weekly basis.
When you right click on the database (not table) tree to perform these functions, the GUI that comes up will tell you the % free space. In our case, when it gets below 1%, the machines will stop.
Hello, Does anyone experience of having "Unable to start process for the following command: DatalogOn xxxxx`" ? How to fix it? Thanks for your...
1,649
I'm trying to figure out what would be the best way to have a plc change a tag to "1", once FTVIEW SE see's that this tag is '1" it would log one...
4,305
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
92
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
42
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
196
