FTView Graphic Import limitations?
phuz
Jun 2008
Mohnton, PA
1,046
I recently upgraded a PV1400e to PVPlus and the conversion utility was mediocre, at best. It missed a lot more things than I am used to and implemented a "Check and revise..." to many of the expressions as well as adding a "/(10**1)" to many of the numeric displays. Because the Find/Replace built into FTView Studio is borderline useless, I opted to export all of the displays to XML and use Notepad++ to Find/Replace within all my files, which worked GREAT! (Kudos, Notepad++). Unfortunately, upon importing the files back into FTView, the expressions were not updated. I chose "Create new" and "Update existing" and neither worked. So basically the import feature is also useless? Looking for some verification.
Import feature works whenever I've used it, but that's with doing a simple export from one, and importing to another. I've never tried editing with notepad... that may be your issue?
I agree that the find/replace and most modern features are either worthless or non-existent in FactoryTalk.
where do i find FTVIEW HMI Enhanced graphic as per attached HMI screen snapshot i had tried its library:scratch: object but they are not similar...
2,159
Hello, I am fairly experienced programming and modifying existing FTView ME programs. I have also used FTView SE to make modifications to a...
136
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
216
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
53
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
209
