FTView "Reinventing the Wheel"
lectrofly
Sep 2009
Iowa
25
Hi everyone,
I've been working with FTView for around 5 years now. I often wonder how many others out there have recreated similar pages, objects and animations (which I have put some serious time into) to those done by someone else.
Currently, I am creating FTView screens to emulate the old Panelmate Power Pro HMI terminals and wonder if someone else out there has already created some of these object and animations.
I am presenly using FTView 5.0 on a distributed system along with RSView SE 4.0 on another distributed system.
I am especially interested in "objects" and entire gfx display pages. Bitmaps and JPegs aren't nearly as desireable unless someone knows how to convert them into "objects" in FTView, otherwise they are nothing more than wallpaper.
If anyone knows of some links to forums, tricks, tips, or whathaveyou, I would appreciate a reply.
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
35
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
182
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
234
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
97
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
94
