FTView SE - unable to delete application or add network server
phuz
Jun 2008
Mohnton, PA
1,044
I've got an HMI distributed application for this customer, but we recently changed it (in our office) to a network station because distributed isn't necessary (only one HMI server). I am trying to delete the network distributed, but it is not allowing me. I continually get the "Unable to perform operation. The application named '....' is in use." I tried using the SE services to stop it, but it doesn't work. All the clients are disconnected, too.
Further, when I go to each client, and try to create a new .cli file, the application does not show up when I choose Network Station. The FT directory is properly connected to the right directory server, so I don't understand why it's not seeing it, unless the network distributed application is still active and not letting another HMI server become visible.
Thoughts?
I wonder if the application manager would still work in Windows Safe Mode. There has to be something running that is still talking to the distributed application somewhere.
It's Rockwell Garbage. Back up the application, wipe the computer HDD clean, reinstall the Rockwell Garbage you need, restore the application.
Or just run it on a VM. Or even a VM within a VM. Can't be too careful with Rockwell Garbage.
This has been answered already I'm sure.
In my case it was the alarm server. I needed to turn off 2 things then run application then close before I could delete and update it. One thing was the ft alarms and events. The other maybe the tag server? It was a stand alone application. Shutting down services had no effect and it's not even possible to shut down all rockwell.
I wrote a script for windows to stop and disable all Rockwell services, and one to re-enable and start them. Unfortunately, it gets stuck when one of the 87,289,283 idiotic Rockwell services are just stuck due to poor programming.
First time using SE and I'm stumped on this one. I've developed my app, tested it within Studio to a live PLC, I have a valid license. Running...
3,212
Hi all, My company is building a machine that has a HMI that uses FTview SE Network distributed system. the HMI server and network directory are...
5,780
I have a Pheonix Contact Industrial PC running FactoryTalk View ME Station V6.10.00.9(CPR 9 SR 4). This terminal worked fine at the Machine...
25,136
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
48
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
