FTVME .db.wat ghost from old project
jdbrandt
Oct 2002
Pennsylvania
1,203
While creating a runtime, the progress window shows:
compression
Tag\ABC1_ABC.db.wat
The ABC1_ABC is a project\target\tag\???? from a previous version or upload of this project.
No reference to any element in the project, with a name or identifier of ABC1_ABC
What is it, and how do I get rid of it?
compression
Tag\ABC1_ABC.db.wat
After a fair effort on KB, I tried to clean up the database, using the procedure detailed in article #927828. In Step 6 of that article, I found the file named ABC1_ABC.db.wat, and, even though it didn't tell me to delete it - I did.
Now off to the testing lab, to see if there were any bad impacts. (The runtime creation worked without errors)
Hi, We don't do many Rockwell projects but recently did onw with a Control Logix and Panelview. What files do customers expect when you send...
264
So I have a PVP7 with keypad and a trend screen setup. I started fumbling around with buttons and managed to move the trend forward and backward...
942
I was about 9/10 done building a new HMI program using both HMI tags and direct reference tags. I was testing it to make sure all of the bugs were...
1,681
I am trying to replace a Panelview Plus 600 from a machine. The HMI works it is just damaged on inside plastic and won't stay together. I uploaded...
1,306
Hello- I have a project where I have 3 buttons that write a value to a register (off/man/auto equals 0/1/2). I want the current mode to highlight...
1,728
