FTVME Sync the Trend Stream
Snyd1
Jun 2018
there
225
So I have a PVP7 with keypad and a trend screen setup. I started fumbling around with buttons and managed to move the trend forward and backward but now I cannot get it to "sync" back to normal where the trend is following real time. Worse than that I did a new download to remove the ability to move around via the keypad and it jumped the trend screen to a future time. Is there any easy way to reset/sync/home the trend screen so that the display is consistent with real time? I believe I have FTVIEW ME 11 maybe 12 installed or something the application and PVP7 are v10.
Edit: Well the issue with it going to a future time after the download was I disabled auto scrolling. Still like to know if there is a way to sync the trend display if I were to use the arrows to move. I can live with it being disabled atm though.
Hi, We don't do many Rockwell projects but recently did onw with a Control Logix and Panelview. What files do customers expect when you send...
284
I was about 9/10 done building a new HMI program using both HMI tags and direct reference tags. I was testing it to make sure all of the bugs were...
1,699
I am trying to replace a Panelview Plus 600 from a machine. The HMI works it is just damaged on inside plastic and won't stay together. I uploaded...
1,319
While creating a runtime, the progress window shows: compression Tag\ABC1_ABC.db.wat The ABC1_ABC is a project\target\tag\???? from a previous...
1,576
Hello- I have a project where I have 3 buttons that write a value to a register (off/man/auto equals 0/1/2). I want the current mode to highlight...
1,740
