Fx2n-2ad
ddtcman
Mar 2012
California
There are some previous posts on reading the A-D value (voltage) from a Mitsubishi 2ad module. I am able to use Mitsubishi's example to store the value in a dxxx register. does anyone have knowledge of how to convert the dxxx value to an actual dc voltage reading?
I'm not sure I understand what you are asking, but I will take a stab...
If your analog input is voltage, (i.e. 0-10 vdc), this voltage will correspond to a digital value that is sent to the PLC. In the FX series, I believe you will need to look in the manual for the analog input module to see what the default digital resolution is. (If memory serves me correct it should be 0-4000.)
So if you are reading in 2000 as a digital value you should have 5vdc coming into the analog input channel.
You can change to a higher resolution by changing a buffer memory.
Hope this helps.
Yup...
That fixes it... Duh... Mitsubishi has the 0-400 resolution for 0-10vdc and my analog device has an output of 0-5vdc...Thanks!
Hi all. I have one module real analog Fx2n-2AD. in document user manual, I see it support for 0-10V( 2.5mV), 0-5v(1.25mv) or 4-20mA. But i don't...
1,754
Hi Mitsubishi FX2N-2AD is a two-channel ana-dig converter..On one channel there is a slot for V, I & com..My question is, provided I have used...
2,059
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
138
Dear all, what type of built in port does fx2n-80mr plc has? i mean is it rs232, r rs422 or rs485. and which module should i use to convert to...
136
Hello everyone, I am currently facing a challenge while trying to connect two Weintek HMI units with a Mitsubishi FX2N PLC. When connecting a...
578
