FX3U ethernet connection status
dmta
Sep 2015
Tyhk
Dear all,
I am using an FX3u PLC along with an FX3u-ENET-ADP card and the card is connected to a PC which runs kepServer 5.19
Is there a way for me to know (from the PLC end) whether the communication between PC and PLC has been established (some sort of a special relay would be really good) ?
Best ragerds
FX3U - Ethernet module - Beiger 1151hmi I have these setup on a press which all worked fine. But since swapping the FXU3-80 for a smaller FXU3-48...
2,875
Hi, I am working on Mitsubishi PLC project.I am using two PLC below. PLC 1 - FX3U (Master) IP : 192.168.0.10 PLC 2 - FX3g (Slave) IP ...
4,701
Wonder if some1 can help me. Im busy with a project and using a FX3U plc with a FX3U-ENET-L ethernet controller connected to a Beijer E1071 HMI...
4,083
Hey, I've som problems with the PLC to communicate through a router or switch using an FX3UENET module. When I connect directly to my PC, it work...
1,710
My setup is as follows: FX3U PLC with ENET module. IP address 192.168.100.201. Have a Melsoft connection set for connection 4. Router: LAN...
6,359
